Problem with HOT_Ocean_Eval VOP
rurik
Hello
I'm running Houdini 11.0775, and am running into a problem with the HOT_Ocean_Eval VOP.
I'm on a Mac
I had to install the DSO/OTLs manually because if I tried to run the Env command and then run Houdini from the terminal I would get an error on startup that would crash Houdini : "Couldnt open fuse 11.0.775/Fuse_ColorOptions.ui"
So once I install everything manually, things work fine, the OTL works great, but the VOP has errors. I've attached a screengrab that shows the errors...
What is the best way to fix this?
Thanks
Alex
I also run a mac and cannot say I have had any problems what at all with compiling or reading the dso's/otl files. In your houdini.env file all you need is the path to the compiled version of the hot toolkit. ie HOUDINI_PATH=/Volumes/Macintosh HD/Houdini_Mprojects/hotbin_osx_H11.0.770_1.0rc9;&;
There is never any need to manually move any file at all. I have a compiled .770 to hand ( see attached) its the latest I am currently using.
Rob
hotbin_osx_H11.0.770_1.0rc9.zip
