few_a_fx Posted June 18, 2011 Share Posted June 18, 2011 I'm trying to run a rbd simulation where a window unit breaks; however the sim keeps crashing around frame 100, so I'm not able to fully bake or even see how the final animation looks. I had a similar problem with a particle fluid animation, I just lowered the particle count. It worked, but the water doesn't look as well as it should. I plan on compositing the final animation into a live action plate, so I need it to look as real as possible. Any suggestions on how to run/bake the simulation without it crashing due to not enough memory? I have a PC with 6g RAM, running windows 32 bit. Quote Link to comment Share on other sites More sharing options...
sam.h Posted June 18, 2011 Share Posted June 18, 2011 (edited) You really need to run Win 64 bit with Houdini 64 bit. With 32 bit you aren't even using all of your ram. 6GB is pretty low as well -- ram is cheap! For some perspective, the machine I use at work has 32GB and I run out sometimes. However that is mostly from multiple sessions and mistakes ... Edit: Sorry, I don't know how to reduce memory usage on an rbd sim, maybe ODE would be more efficient? how about less divisions on your collision volume, hide everything you don't need in your scene, get rid of attributes in your scene, running houdini from the command line will give you more memory to work with too... Edited June 18, 2011 by sam.h Quote Link to comment Share on other sites More sharing options...
symek Posted June 18, 2011 Share Posted June 18, 2011 (edited) I have a PC with 6g RAM, running windows 32 bit. So you're not using upper 3GB of RAM at all. Get any x64 system first. Easiest way is to install any human-friendly Linux, like Ubuntu. Additionally: WindowsVista ~= 700MB of RAM Ubuntu 9.1 ~= 140MB of RAM Ubuntu 9.1(no X server running) ~= 70MB of RAM empty session of Houdini 11 with GUI ~=140MB of RAM empty session of Hbatch 11 (no GUI) ~= 40MB of RAM Also tuning cache setting of your simulation may help. I can't check it for sure now, but turning on explicit cache on DOP network should save you some RAM. Edited June 18, 2011 by SYmek Quote Link to comment Share on other sites More sharing options...
few_a_fx Posted June 18, 2011 Author Share Posted June 18, 2011 Right now I can't afford a 64 bit system, will switch when able too. Anyways thanks for the tips. I'll try out the cache, command line and ODE stuff. Thanks. Quote Link to comment Share on other sites More sharing options...
few_a_fx Posted June 18, 2011 Author Share Posted June 18, 2011 Using the explicit cache seems to be working. I can finally see whats going on. Going to try and run it through the command line, so it sims while I'm at work. Will keep you updated. Thanks again sam.h and SYmek Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 20, 2011 Share Posted June 20, 2011 Just make sure you have plenty of hard drive space to cache to. Also, if you are going to rely on caching heavily, an investment in a low seek HDD or a 32gb SSD would be very beneficial. I know that in my next system, I am going to be putting an SSD in that I will use for nothing but caching simulations and geometry. The last thing you want to have happen is to be caching a detailed sim and run out of space. Quote Link to comment Share on other sites More sharing options...
few_a_fx Posted June 21, 2011 Author Share Posted June 21, 2011 Just make sure you have plenty of hard drive space to cache to. Also, if you are going to rely on caching heavily, an investment in a low seek HDD or a 32gb SSD would be very beneficial. I know that in my next system, I am going to be putting an SSD in that I will use for nothing but caching simulations and geometry. The last thing you want to have happen is to be caching a detailed sim and run out of space. I just got a new hard, 1TB. So I'm ok on that. Quote Link to comment Share on other sites More sharing options...
