pgrochola Posted June 19, 2011 Share Posted June 19, 2011 Hi, I've been playing around with the "Voronoi fracture configure object" and it's generally doing a great job. One thing I'm stuggling with is getting a veriety of chunk sizes. As far as I can tell the impact radius doesn't give me control over the size of individual pieces, just where they are created. Does anyone know a good way of getting control over chunk shattering on a more "manual" way? For example, after the initial break I want to pick out a chunk and fracture it again into really small pieces. What would be the best way to go about this? Thanks! Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 20, 2011 Share Posted June 20, 2011 I haven't gotten into fractures in Houdini, but I am sure there is a way to control the fracture size based on a ramp value. Saying that the closer to 1 the value is, the smaller the pieces are, then just use a radial ramp to fall it off to the large slabs of material. or even have it not fracture at 0. I would imagine that this could produce some very nice bullet effects... maybe I should give this a shot, it sounds like fun. Quote Link to comment Share on other sites More sharing options...
pgrochola Posted June 22, 2011 Author Share Posted June 22, 2011 I haven't gotten into fractures in Houdini, but I am sure there is a way to control the fracture size based on a ramp value. Saying that the closer to 1 the value is, the smaller the pieces are, then just use a radial ramp to fall it off to the large slabs of material. or even have it not fracture at 0. I would imagine that this could produce some very nice bullet effects... maybe I should give this a shot, it sounds like fun. Sounds good. If you figure it out let me know! Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 22, 2011 Share Posted June 22, 2011 (edited) I am still very new it Houdini. I haven't even figured out how to make a radial gradient yet or shatter an object, let alone combining the two... so it may be a while. I just know that as a thought experiment, that method is sound. I will be trying to figure it out over the next few months though. Edited June 22, 2011 by Adam Ferestad Quote Link to comment Share on other sites More sharing options...
