Volume Density Gradient
Macha
I'm looking for a way to ramp the density of a volume in a controlable and smooth way.
Say you have a cloud of arbitrary shape. I want to increase the density as we get closer into the center of the cloud. There are 2 problems with this:
1) How do I find the (local) center of a cloud? I have done something similar here:
The particles in that video travel to the nearest central part of the object. However, that method is unsuitable for my purpose because it needs to run a pop to find the center.
2) How do I ramp a volume in a visually pleasing way? I always get either-superdense or super-weak results. So, the density ramps in a non-linear way. Looking at the default volume shaders it looks like it is something exponetial.
So far what I have done is to create a point cloud and blend an attribute from the surface of the volume. I create a field out of those attributes and use it multiply density. But as I said there are those 2 problems with. I tend to get volumes with a very visible and sudden increase in density, wheras I want a smooth one.
Makes sense?
Why don't you use an SDF? you can make one with iso offset and then remap the values with a volume vop?
I can post an example file if you like?
You won't really ever get a 'linear' ramp (in screen) out of a volume... although you can get a more pleasing one by powering the density ...
