junyd Posted June 26, 2011 Share Posted June 26, 2011 Hi everyone, Every time i try to scale my containers i get this weird lining pattern on the voxels. Attached are the images to see. thanks Quote Link to comment Share on other sites More sharing options...
hkspowers Posted June 26, 2011 Share Posted June 26, 2011 Hi everyone, Every time i try to scale my containers i get this weird lining pattern on the voxels. Attached are the images to see. thanks I have not used pyro yet but if it's anything like Maya's fluids a non uniform scale will stretch the appearance because each voxel is not a perfect cube. Quote Link to comment Share on other sites More sharing options...
sam.h Posted June 26, 2011 Share Posted June 26, 2011 In the second image the lines look like shadow map artifacts. Does the pattern appear in the alpha? If it doesn't, then it is the shadow map (turn up pixel samples on the shadow map) Quote Link to comment Share on other sites More sharing options...
divi Posted June 26, 2011 Share Posted June 26, 2011 (edited) Don't you have to resize the fluid box. You can't just scale it. Go into AutodopNetwork > pyro > size. (second image)For the lining. try putting the shadowmap>shadow blur =0.01 in the light's shadow tab. I've been learning Pyro and smoke for 3 days with Peter Quint's tutorials. You should check them out if you haven't. http://sites.google.com/site/pqhoudinitutorial/home/videos-on-dynamics Edited June 26, 2011 by divi Quote Link to comment Share on other sites More sharing options...
junyd Posted June 29, 2011 Author Share Posted June 29, 2011 hkspowers thanks. divi thanks. it worked out. sam.h yeah it doesnt show up in alpha. thanks a lot. Quote Link to comment Share on other sites More sharing options...
