Kai87 Posted June 26, 2011 Share Posted June 26, 2011 Hello I am working on my final masters project at uni and I was just after some help or tips on how to go about some areas. I have a basic design where I have four main curves animating, however what I would like to know is how to have these curves to animate all at the same point, so that when I animate them it generates the boxes etc to how have them moving at the moment but keeping the same look as the original shape, like a snake moving basically. Another area which I which I am abit stuck on is how I would render out this animation and uv project it onto some dummy geometry, like I have on the arm network. I can uv project it as a tiff sequence, but it doesn't animate. Here is my project file so far. Thanks Kai Proof_of_Concept_odforce.hipnc Quote Link to comment Share on other sites More sharing options...
Kai87 Posted June 29, 2011 Author Share Posted June 29, 2011 Solved the first problem, used soft transform, which did the trick! Quote Link to comment Share on other sites More sharing options...
