Multi channel PC write VOP ?
rob
Does Anyone happen to have a Multi channel PC write VOP they would care to share ?. Currently the one that comes with Houdini holds only 2 channels.Having a lot more would be more useful
Kind regards
Rob
Edited by rob
Kind regards
Rob
Here you go :)
If you do "type properties" and look in the Code and Input/Output sections it will be fairly obvious how you can add as many as you want.
AXIS_pcwrite.otl
