control display flag outside a digital assest
Bin
Greetings people,
when creating a digital asset and managing the type properties, is there a way to control the display flags?
I mean, is it possible to create a button in the parameters to control certain inner nodes' flags to switch between bypass on/off as well as display? does that requires a whole bunch of scripting? or there is some simpler way to work around?(switch node? possibly?)
thanks
The nature of an asset means that all of those things are locked. You can modify nodes by making editable nodes to do as you want, but the proper method is to use switch nodes. Switches just need a simple channel reference where as dealing with the editable nodes and flags requires some sort of scripting.
yea,thanks.
Switch makes bypass simple enough,
but the "display" parameter under Render tab is for geometry node, right? if I wanna control the display of the nodes inside the geometry node, then what can I do?
Edited by Bin
  • 3 years later...
