blur959 Posted July 1, 2011 Share Posted July 1, 2011 Hi all, I am trying to get the position data of my simulation in dops and group them according to a certain condition. However I don't seem to be getting what I am hoping for. Can anyone point out to me what did I do wrong? The expression I used was, if(dopfield("/obj/dopnet1", "rbdfracturedobject1", "Position", "Options", 0, "py")>0, 1, 0) And my file in case. Thanks! velocity_check3.hip Quote Link to comment Share on other sites More sharing options...
anim Posted July 8, 2011 Share Posted July 8, 2011 (edited) a few things: no /obj/dopnet1 exists, it is /obj/geo1/dopnet1, but you better reference it just as ".." no rbdfracturedobject1 dop object exists, it's just a name for the node, the objects are called piece1-piece99 so use $OBJNAME instead "py" refers to pivot y value, to get position(translation) use "ty" no if() is needed for simple comparison so it would look like this: dopfield("..", $OBJNAME, "Position", "Options", 0, "ty")>0 edit: since you can have more dop objects with the same name maybe $OBJID would be better than $OBJNAME Edited July 8, 2011 by anim Quote Link to comment Share on other sites More sharing options...
blur959 Posted July 11, 2011 Author Share Posted July 11, 2011 a few things: no /obj/dopnet1 exists, it is /obj/geo1/dopnet1, but you better reference it just as ".." no rbdfracturedobject1 dop object exists, it's just a name for the node, the objects are called piece1-piece99 so use $OBJNAME instead "py" refers to pivot y value, to get position(translation) use "ty" no if() is needed for simple comparison so it would look like this: dopfield("..", $OBJNAME, "Position", "Options", 0, "ty")>0 edit: since you can have more dop objects with the same name maybe $OBJID would be better than $OBJNAME Thanks man, it worked perfectly. Quote Link to comment Share on other sites More sharing options...
