procedural dissolve problem
jim c
Let's say I've got a polygon with N sides. I'd like to convert this to a line segment with the last edge deleted so it's no longer a closed curve. Currently I'm using the Ends SOP to unroll it, then a dissovle SOP to delete the last edge. Here's the tricky part that I don't get how to do:
In the dissolve SOP I need to specify the edge like so: p0-(N-1), hardcoding it so it's something like "p0-8". Is there any way I could insert the "8" part of the string through expressions? I've tried a couple things but they don't work and I must be screwing up the syntax somewhere.
if you set Ends SOP to Open instead of Unroll it automatically deletes the last edge
or if you are dissolving with Dissolve SOP, you don't need to unroll before
or if you have it already unrolled, just delete the very last point with delete SOP
Edited by anim
