AdrianLazar Posted July 13, 2011 Share Posted July 13, 2011 Hi guys, I would like to deform an object using a low poly version that has a soft body simulation in order to optimize the simulation time. So basically I have a raspberry fruit that I want to fall down the table and squish a little. But I think simulating the fruits (5 or 6) would be very time consuming so I was thinking to make a lowrez version that will be simulated and then used to deform the high rez one. Is for the Cook-Off contest here: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22574 so I hope it's not against the rules to ask for help Many thanks, -Adrian Quote Link to comment Share on other sites More sharing options...
mdunkley Posted July 13, 2011 Share Posted July 13, 2011 Hi Adrian - have a look at either wire capture/deform or the lattice sop set to point mode - i think either of those would get you where you want to go. Quote Link to comment Share on other sites More sharing options...
luoqiulin Posted July 14, 2011 Share Posted July 14, 2011 here is a tutorial and scene files,it's your need sidefx Quote Link to comment Share on other sites More sharing options...
peliosis Posted July 14, 2011 Share Posted July 14, 2011 Also be sure you've checked this : houdinitools There is a very nice PGMVC deformer. Quote Link to comment Share on other sites More sharing options...
AdrianLazar Posted July 14, 2011 Author Share Posted July 14, 2011 Lattice works great guys! Many thanks! Quote Link to comment Share on other sites More sharing options...
