asnowcappedromance Posted July 14, 2011 Share Posted July 14, 2011 hi guys, I have a sph fluids workflow question. There are 2 different particle fluid objects (sph) sitting in my scene, both connected to a merge node which is plugged into a particle fluid solver. In this solver I control the objects viscosity and elasticity. Now I want to get 2 different consistencies for the 2 fluid objects (one sticky fluid, one waterlike) and I have no clue how to achieve this. Already tried dopoption expression or setting up attributes with the popsolver and then a point expression (if statement) to seperate the values, but it only ever takes one value into account. So what's the way to do this, 2 different solvers? cheers, Manuel Quote Link to comment Share on other sites More sharing options...
Nik S Posted July 14, 2011 Share Posted July 14, 2011 So what's the way to do this, 2 different solvers? I would take a stab at 2 different SPH fluids with 2 separate solvers, then plug them both into a multisolver node, There may be a cleaner way, but this seems the most straightforward to me. - N Quote Link to comment Share on other sites More sharing options...
asnowcappedromance Posted July 14, 2011 Author Share Posted July 14, 2011 I would take a stab at 2 different SPH fluids with 2 separate solvers, then plug them both into a multisolver node, There may be a cleaner way, but this seems the most straightforward to me. - N I will give it a shot. What about substeps, do they all have to have the same values or how does it work? Quote Link to comment Share on other sites More sharing options...
asnowcappedromance Posted July 15, 2011 Author Share Posted July 15, 2011 well I tried a couple of things here and seem to get nowhere I attached a file where I tried using a multiple solver as you suggested. Also put the 2 fluid objects into different groups to be able to address them. Thanks for the help, Manuel fluids_different_consistency.hipnc Quote Link to comment Share on other sites More sharing options...
pclaes Posted July 15, 2011 Share Posted July 15, 2011 This is with flip, but might work for your needs too: And this is a hack that can also work: Quote Link to comment Share on other sites More sharing options...
