Xsiv Posted July 14, 2011 Share Posted July 14, 2011 I am now tearing through a cloth curtain. It really blows apart. I want most of the cloth to move, but only to tear at the point of impact. My thoughts are: Write an expression on the Tear Threshold based on each point's position from the point of impact. ImpactPos - $PT = dist. Divide this by the size of the object to normalize and put that in the Stretch/Shear/Bend of the Tear Threshold. I am not sure how to write this. If I put a dummy object at the point of impact, use its transform? Suggestions? Thank you Chris SlicedCurtainExpression.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted July 14, 2011 Share Posted July 14, 2011 (edited) what about just using Paint Tearable shelf tool? you can paint weak spots on cloth it will create point attributes (stretchtearthreshold, sheartearthreshold, bendtearthreshold) on source geometry which will be used as multipliers to Stretch/Shear/Bend Tear Threshold parameters if you really need to do that procedurally, I suppose you can change/create that attributes in SOP Solver, and since you can use SOP nodes inside SOP solver, you can use many ways to make just impact area tearable, attribtransfer or VOPs, or just Point SOP with something like your mentioned expression Edited July 14, 2011 by anim Quote Link to comment Share on other sites More sharing options...
Kevju Posted November 16, 2012 Share Posted November 16, 2012 I'm sorry to upping this topic, but where is Paint Tearable Shelf Tool? I'm in Houdini 12.1 and in my cloth Shelf I'have not this tool : only Cloth Object, Cloth Body, Attach Cloth, Cloth Follow, Stitch Cloth, Cloth Proxy and Distribute. Quote Link to comment Share on other sites More sharing options...
anim Posted December 9, 2012 Share Posted December 9, 2012 you are right, it disappeared, puff houdini obviously does more magic than we might like you can create new tool in the shelf and put this into script tab import dopclothtoolutilsdopclothtoolutils.selectAndPaintTearableClothObjects(kwargs)[/CODE] Quote Link to comment Share on other sites More sharing options...
