practjin Posted July 20, 2011 Share Posted July 20, 2011 (edited) Hi, there~ I have been trying to simulate buoyancy with flip solver. When the object is in the particle fluid, I want to add buoyancy force to the object as setting density lower than fluid particle, but it does not well. In contrast, doing it with sph solver looks good. Of course, in this case, doing with sph solver is correct. but another what I want to do is interaction between different types of fluids particle. unfortunately, sph solver is not doing well in this situation . because, when initial particle interaction with emiting particle, it explosion. In contrast, flip solver looks good. So, my conclusion is that.... is there a method to add buoyancy force with flip solver? Edited July 21, 2011 by practjin Quote Link to comment Share on other sites More sharing options...
yongbin Posted July 21, 2011 Share Posted July 21, 2011 sorry for your disappointing, But. nice to meet you Quote Link to comment Share on other sites More sharing options...
practjin Posted July 21, 2011 Author Share Posted July 21, 2011 sorry for your disappointing, But. nice to meet you Oh~ thanks for your reply, nice to meet you too. actually, I expected a little bit. ha ha just kidding~ have a nice day~ Quote Link to comment Share on other sites More sharing options...
ikarus Posted July 21, 2011 Share Posted July 21, 2011 you can fetch the surface data from the flip object and use that as a field for a buoyancy force should the feedback setting do this automatically though? Quote Link to comment Share on other sites More sharing options...
practjin Posted July 21, 2011 Author Share Posted July 21, 2011 you can fetch the surface data from the flip object and use that as a field for a buoyancy force should the feedback setting do this automatically though? I also had tested about it but i had forgot feedback setting. once more I have try this to include feedback setting. and this is doing very well. I solve it with your reply. thanks ~ ikarus Quote Link to comment Share on other sites More sharing options...
bunker Posted July 23, 2011 Share Posted July 23, 2011 You just need a gasBuoyancy microsolver and give it a field in "temperature", that will update you vel field. Hi, there~ I have been trying to simulate buoyancy with flip solver. When the object is in the particle fluid, I want to add buoyancy force to the object as setting density lower than fluid particle, but it does not well. In contrast, doing it with sph solver looks good. Of course, in this case, doing with sph solver is correct. but another what I want to do is interaction between different types of fluids particle. unfortunately, sph solver is not doing well in this situation . because, when initial particle interaction with emiting particle, it explosion. In contrast, flip solver looks good. So, my conclusion is that.... is there a method to add buoyancy force with flip solver? Quote Link to comment Share on other sites More sharing options...
practjin Posted July 24, 2011 Author Share Posted July 24, 2011 You just need a gasBuoyancy microsolver and give it a field in "temperature", that will update you vel field. nice~ thanks bunker~ Quote Link to comment Share on other sites More sharing options...
kuimig Posted August 8, 2014 Share Posted August 8, 2014 good job bunker~~ Quote Link to comment Share on other sites More sharing options...
