moving geometry with particles
ehsan parizi
Hi all,
I have a fractured geo, and a pop-network that generates 1 particle in the middle on top surface of every piece* at frame 1 ( basically 1 particle per piece ). How can I copy each piece to a corresponding point/particle? I know it can be done by foreach sop, but I couldn't make it!
you can use copy node in combination with swich node to do this. you can swich geometry per point and copy them to the points.
create a variable for the parameter swich and use it to copy different geometries.I can post you a hip file if you need.
