merging mutliple subnet geometries
Subnet1
        subnet2
               geo1 geo2 geo3
        subnet3
               geo4 geo5 subent6
        subnet4
               geo6 geo7 geo8
        subnet5
               geo9 geo10 subnet6
                                geo11
This is my Network after importing FBX from maya.
for the sake of easy control, I need to bake this main Subnet1 on top of all the child geos.
I tried Combine tool on the shelf but it works for one subnet.
I can manually loop this process until combine all the subnet, but is there a easy way to combile all the geos in one subnet no matter child is subnet and it contains more than 1 subnet again.
It's so picky to do that all the time
Edited by jackytop
when importing FBX un-check Import Null Nodes At Subnets parameter
that way it will import all your geometries into one subnet making whole process easier
or of course you can use python to recursively merging geos from nested subnets, but there is no need if you can reimport FBX
Ok! I totally forgot that option. Thanks anim! I will re-import and check.
Peace!
