sphere on mouse
Bin
Hi, I am running into this situation that I want to attach a simple sphere onto the mouse just for display purpose.
the "mouse" chop gets the position x y on screen space, but I don't know how to convert it to the 3d space coordinates so I can feed it into the translate of the sphere to let it move accordingly...
or maybe there's other solution for this?
thanks
I guess you cannot translate them to 3D unless you can gather viewport position and dimensions (I didn't find a way to do that)
because mouse chop will return mouse position normalized to whole screen
but you can use Paint SOP which can gather info about mouse position in 3D space as well as other data like hit primitive and hit UVs, etc.
you can then record that data with Record CHOP or something
but this may not be what you want, because while you are recording the mouse position you need to be in active Paint SOP, so if you want that as realtime cursor while working then you may be out of luck, but otherwise it may serve you just fine
