jim c Posted July 26, 2011 Share Posted July 26, 2011 I notice that when I render hair on the model with none of the ZBrush displacement/texture maps on, the render takes place very fast. When I turn off the hair and render with the ZBrush displacement/texture maps ON, the render happens pretty quick. When the hair is rendered *AND* the displacement/texture maps for the character mesh are turned on, then the render slows to a crawl - orders of a magnitude slower at least. If it matters, I've got two lights, both with deep shadow maps turned on. I'm rendering using the micro poly renderer. The hair count is at 200,000 hairs for the render. I'm using the default hair shader. Is there something stupid that I'm doing? Quote Link to comment Share on other sites More sharing options...
jim c Posted July 26, 2011 Author Share Posted July 26, 2011 Another possibility occured to, maybe this is making this too complicated. Would it make sense to render the hair in a separate take? So you could render the character with GI lighting on and hair off, then render another take with the GI lighting off, hair on, and the character as just as matte (I guess that's the right term) or maybe something that will catch shadowns. Then composite the two parts together? Would that make more sense? Quote Link to comment Share on other sites More sharing options...
old school Posted July 27, 2011 Share Posted July 27, 2011 Yes that would work. Just apply a matte shader to your skin for the hair pass and comp together. The deep shadow maps on the lights when set up right should create nice opacity. Quote Link to comment Share on other sites More sharing options...
jim c Posted July 27, 2011 Author Share Posted July 27, 2011 Thanks, are there any other techniques that are worth looking into besides this? Any hints for best settings for the shadow maps to get them to look nice? Quote Link to comment Share on other sites More sharing options...
jim c Posted August 3, 2011 Author Share Posted August 3, 2011 Yes that would work. Just apply a matte shader to your skin for the hair pass and comp together. So I got a chance to experiment with this. I did get it to work but ran into a snag. To make it work I used a shadow matte on the character for the Hair take. Works fine, but...since it doesn't have a displacement map associated with it, it doesn't track 100% to the outline of the fully textured and displaced render of the character. And you can see this when you comp the two passes together If I tinker with a custom shader, and add the displacment back in, then the time goes wayyyy back up. I presume that the displacement is adding all sorts of new calculations for where the shadows will fall and this, combined with the presence of the hair strands, is what's causing the high render time? So is there another technique I should be looking at, or is it simply the case that rendering hair and shadows is just really expensive (time wise) and there's really no way around that? Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted August 3, 2011 Share Posted August 3, 2011 So I got a chance to experiment with this. I did get it to work but ran into a snag. To make it work I used a shadow matte on the character for the Hair take. Works fine, but...since it doesn't have a displacement map associated with it, it doesn't track 100% to the outline of the fully textured and displaced render of the character. And you can see this when you comp the two passes together If I tinker with a custom shader, and add the displacment back in, then the time goes wayyyy back up. I presume that the displacement is adding all sorts of new calculations for where the shadows will fall and this, combined with the presence of the hair strands, is what's causing the high render time? So is there another technique I should be looking at, or is it simply the case that rendering hair and shadows is just really expensive (time wise) and there's really no way around that? If you are using micropolygon rendering you could reduce shading quality on your matte object. Then you will still get displacements but they will compute faster as it wont make such small micropolygons. They will probably on the other hand be small enough for just a matte. Quote Link to comment Share on other sites More sharing options...
jim c Posted August 4, 2011 Author Share Posted August 4, 2011 OK got it to work. I rebuilt the shader from scratch again, and this time it didn't cause the render slow downs. I must have done something incorrect before. I'll check out the render settings but for now it's pretty good. Quote Link to comment Share on other sites More sharing options...
