Calling meshlab via the Unix SOP
Hi there~
I have been trying to surface points which is simulated by particle fluid solver in dops. I don't want using particle fluid surface, because I want to apply procedural noise shader.
One of the way surfacing points I founded in Sesi forum is that using the Meshlab via the Unix sop.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22672&sid=e43ceccc8e60dddf752ed8ca5af890b0
In above post, edward post reply that write a wrapper script that calls MeshLab via the Unix SOP.
So, I have been trying to find appropriate example scripts but i can't find it.
anybody who knows about commander which is calling external program or appropriate example scripts?
Edited by practjin
