Barakooda Posted August 3, 2011 Share Posted August 3, 2011 How to shift animation channel procedurally ? :-) example attached. B. channel_animation_start_point.hipnc Quote Link to comment Share on other sites More sharing options...
Barakooda Posted August 3, 2011 Author Share Posted August 3, 2011 How to shift animation channel procedurally ? :-) example attached. B. OK, i will answer to my self :-) B. animation_start_point_solution.hipnc Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted August 3, 2011 Share Posted August 3, 2011 That depends on how you are trying to modify the animation procedurally. I have a few in my drama can tutorial, but in general I would probably stick to using a function CHOP with channel references to my parameters on a null node. If you need more information or a specific adjustment, I could help you with what functions to use, or if you need something with integration or derivatives I can help with that stuff. I guess it would really depend on what you are trying to modify about the animation. Do you have any more details on what you are looking to do? Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted August 3, 2011 Share Posted August 3, 2011 Sorry, I meant the Expression node, not the Function. My bad. Quote Link to comment Share on other sites More sharing options...
