live_fx Posted August 16, 2011 Share Posted August 16, 2011 Hi all, please help me solve that error: ~/data/compile/bullet/dop/bullet-physics-solver/src$ ./build.sh Making debug version Linking with 'libBulletDynamics' Linking with 'libBulletCollision' Linking with 'libBulletSoftBody' Linking with 'libLinearMath' Making SIM_SolverBullet.o and /home/xx/houdini11.0/dso/SIM_SolverBullet.so from SIM_SolverBullet.cpp /usr/bin/ld: /usr/local/lib//libBulletDynamics.a(btSequentialImpulseConstraintSolver.o): relocation R_X86_64_32S against `vtable for btSequentialImpulseConstraintSolver' can not be used when making a shared object; recompile with -fPIC /usr/local/lib//libBulletDynamics.a: could not read symbols: Bad value collect2: ld returned 1 exit status Link failed OS: Ubuntu 10.04 x64 Houdini: 11.813 Bullet: 2.78 Bullet-DOP: (i don't know where i can get ver) Thanks for helping ... Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted August 16, 2011 Share Posted August 16, 2011 (edited) Just add -fPIC to your Makefile or where the build settings are specified. Edited August 16, 2011 by Erik_JE Quote Link to comment Share on other sites More sharing options...
live_fx Posted August 16, 2011 Author Share Posted August 16, 2011 Just add -fPIC to your Makefile or where the build settings are specified. Thanks again) I will try Quote Link to comment Share on other sites More sharing options...
live_fx Posted August 16, 2011 Author Share Posted August 16, 2011 Just add -fPIC to your Makefile or where the build settings are specified. looks like hcustom have used this option on compile time: i check that with "-c" option: hcustom -c -DVERSION=\"11.0.813\" -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -DGCC4 -DGCC3 -Wno-deprecated -I/opt/h11/toolkit/include -I/opt/h11/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 ? Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted August 16, 2011 Share Posted August 16, 2011 looks like hcustom have used this option on compile time: i check that with "-c" option: hcustom -c -DVERSION=\"11.0.813\" -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -DGCC4 -DGCC3 -Wno-deprecated -I/opt/h11/toolkit/include -I/opt/h11/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 ? That indeed is already in there. From what repository did you check out the source code? I'll try compiling it here if I get the time. Quote Link to comment Share on other sites More sharing options...
live_fx Posted August 17, 2011 Author Share Posted August 17, 2011 That indeed is already in there. From what repository did you check out the source code? I'll try compiling it here if I get the time. Bullet from there: http://code.google.com/p/bullet/downloads/list DOP's: http://gitorious.org/bullet-physics-solver/bullet-physics-solver (just go in and download "master" tar.gz) Making SIM_SolverBullet.o and /home/roman/houdini11.0/dso/SIM_SolverBullet.so from SIM_SolverBullet.cpp /usr/bin/ld: /usr/local/lib/libBulletDynamics.a(btSequentialImpulseConstraintSolver.o): relocation R_X86_64_32S against `vtable for btSequentialImpulseConstraintSolver' can not be used when making a shared object; recompile with -fPIC /usr/local/lib/libBulletDynamics.a: could not read symbols: Bad value collect2: ld returned 1 exit status Link failed i have not ideas what i can do with that error... Something is wrong with btSequentialImpulseConstraintSolver.o or it's src code.. I think i need Bullet DOP some developers help and attention, may be something versions mismatch... Sad. Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted August 18, 2011 Share Posted August 18, 2011 (edited) Sorry it took some time. Trying to finish up my thesis. Anyways the problem is that bullet itself aint compiled with -fPIC. You can fix this by when creating your makefiles for bullet use cmake . -G "Unix Makefiles" -DCMAKE_CXX_FLAGS="-fPIC" -DCMAKE_C_FLAGS="-fPIC" instead of the regular cmake . -G "Unix Makefiles" After that it compiled fine here. I also used http://gitorious.org/~almatea/bullet-physics-solver/almateas-bullet-physics-solver instead which seems to be a slightly more recent fork but i think it should work with the regular one as well. System specs for my machine: Linux Mint 11 (Ubuntu 11.04) 64bit Houdini 11.0.733 Bullet 2.78 Edited August 18, 2011 by Erik_JE 1 Quote Link to comment Share on other sites More sharing options...
live_fx Posted August 18, 2011 Author Share Posted August 18, 2011 Sorry it took some time. Trying to finish up my thesis. Anyways the problem is that bullet itself aint compiled with -fPIC. You can fix this by when creating your makefiles for bullet use cmake . -G "Unix Makefiles" -DCMAKE_CXX_FLAGS="-fPIC" -DCMAKE_C_FLAGS="-fPIC" instead of the regular cmake . -G "Unix Makefiles" After that it compiled fine here. I also used http://gitorious.org/~almatea/bullet-physics-solver/almateas-bullet-physics-solver instead which seems to be a slightly more recent fork but i think it should work with the regular one as well. System specs for my machine: Linux Mint 11 (Ubuntu 11.04) 64bit Houdini 11.0.733 Bullet 2.78 Thanks ! Today i have found another solution, all works but i'm on testing stage. cmake . -G "Unix Makefiles" -DBUILD_SHARED_LIBS=ON -DBUILD_DEMOS=OFF after that i can compile all what i need.. Now i test DOP and have some troubles. But this is for another thread Thanks Erik_JE ! Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted August 19, 2011 Share Posted August 19, 2011 Thanks ! Today i have found another solution, all works but i'm on testing stage. cmake . -G "Unix Makefiles" -DBUILD_SHARED_LIBS=ON -DBUILD_DEMOS=OFF after that i can compile all what i need.. Now i test DOP and have some troubles. But this is for another thread Thanks Erik_JE ! No problem, good that you got it working. It will be great with the native bullet solver in H12. Quote Link to comment Share on other sites More sharing options...
