sparkChan Posted August 17, 2011 Share Posted August 17, 2011 (edited) hi, Currently I'm doing a project that a font which is under a moutain is coming up slowly. just like you see the below picture, I want to get this effect when the font rises under the moutain. But I don't konw how to get it. I'm trying to use a DopNetwork to simulate that, but the result is not what I want. Maybe I've gone wrong direction. this time I'm planning to use sop to do that work, but I don't know how to start my work. so hopefully you can give me some advice to do that. thanks. test_v01.hip My link Edited August 17, 2011 by sparkChan Quote Link to comment Share on other sites More sharing options...
stephenl Posted August 17, 2011 Share Posted August 17, 2011 (edited) The file is the same as the sphere video and seems to be working fine? You must use DOPS unless you have a custom sop dynamics solver Edit: Maybe you could try extruding the text and try it Edited August 18, 2011 by stephenl Quote Link to comment Share on other sites More sharing options...
Garman Posted August 18, 2011 Share Posted August 18, 2011 Can you write a very detailed description of all the things you want to have happen. It's difficult to give advice because there are so many things that could happen. Quote Link to comment Share on other sites More sharing options...
sparkChan Posted August 19, 2011 Author Share Posted August 19, 2011 Can you write a very detailed description of all the things you want to have happen. It's difficult to give advice because there are so many things that could happen. Simply when the font comes out, the stones around them crack and extrude, just as the above picture shows. I just want to get this which the stones how to interact with the font. thanks. Quote Link to comment Share on other sites More sharing options...
