zoki Posted August 21, 2011 Share Posted August 21, 2011 hi i have coffe cup broken and simulated exported in bgeo sequence also i wrote out sdf sequence for all the breaking of cup and saucer From cup interior i created volume for fluid and simulated initial state in a static cup now i want to use breaking cup to influence fluid and spill itself on a table i double checked normals and sdf all looks ok my cup and saucer are two static but deforming objects with merge setup on left so just ground and cup influence fluid but particle fluid with default settings explodes out of cup on 3rd frame any thoughts and pointers on this one as i wouldnt want to use other application than Houdini for solving it thanks zoran Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted August 21, 2011 Share Posted August 21, 2011 Are you using SPH or FLIP ? Quote Link to comment Share on other sites More sharing options...
zoki Posted August 21, 2011 Author Share Posted August 21, 2011 i switched now from sph to flip the problem was if I read sdf sequence in, it wasnt clear to me at least which parameters are still active or which are overriden in collision tab so it looks that volume based collision on top needs to be ticked off in order for read in to work properly it is simulating now fingers x Quote Link to comment Share on other sites More sharing options...
zoki Posted August 21, 2011 Author Share Posted August 21, 2011 it is working better but i have leakage through walls of cup even though sdf is without holes and substeps to 5 I will switch to sph to see if it helps Quote Link to comment Share on other sites More sharing options...
ikarus Posted August 21, 2011 Share Posted August 21, 2011 flip fluids are really bad at collision detection with moving objects, switching to sph might help, that geo is pretty thin though, might require a good number of substeps Quote Link to comment Share on other sites More sharing options...
zoki Posted August 21, 2011 Author Share Posted August 21, 2011 thanks ikarus i switched it to sph and volume collision detection it is simulating atm will see what happens Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted August 21, 2011 Share Posted August 21, 2011 I would stick with FLIP and cheat some on the collision geometry by offsetting it slightly. Then crank up substeps until nothing is leaking. Quote Link to comment Share on other sites More sharing options...
zoki Posted August 23, 2011 Author Share Posted August 23, 2011 managed to pull this one to render stage hope you like it coffe.movFetching info... Quote Link to comment Share on other sites More sharing options...
