Drawing Geometry in Houdini
Hello, I am trying to wrap my head around how to correctly draw geometry in houdini.
I have a set of points that define a primitive, and a list of faces and vertices of how to draw the geometry
but I am having problem putting this information into the detail.
How do I
*add the points to the detail ( I figure this is done with the appendpoints?
*define my vertices
*define my faces.
*How does houdini knows which points are being share so they are not duplicated?
the problem right now is that if I have 16 points to draw a sphere and I do something like
 for(int x=0; x<columns;x++)
                        for (int y=0; y<rows;y++)
                            //Create face poly
                            GU_PrimPoly *poly;
                            GEO_Point * thisPoint;
                            //first point
                            poly = GU_PrimPoly::build(gdp,4,GU_POLY_CLOSED);
                            int index=getIndexBuffer(x,y,4);
                            thisPoint=poly->getVertex(0).getPt();
                            thisPoint->setPos(sphere_points[index].getPos());
                            //second point
                            index=getIndexBuffer(x+1,y,4);
                            thisPoint=poly->getVertex(1).getPt();
                            //third point
                            index=getIndexBuffer(x+1,y+1,4);
                            thisPoint=poly->getVertex(2).getPt();
                            //fourth point
                            index=getIndexBuffer(x,y+1,4);
                            thisPoint=poly->getVertex(3).getPt();
I ended up having way more than 16 points, beacuse is creating each polygon with unique points.
How do I specify my list of points vertices and faces?
I appreciate the help in advance.
Thanks
  • 2 weeks later...
thanks!
I figured it out, the fact that the Houdini asks for the reference to the points instead of a list of points was a bit confusing.
Here it is how it works, (or how I think it works).
//Create an array that will store the points references
               GEO_Point *sphere_points[myTotalPoints];
//Adding points to the detail and storing their references in *sphere_points
                for(int pc=0;pc<myTotalPoints;pc++)
                    //Creating point in the details
                    sphere_points[pc]= gdp->appendPoint();
//Once you have that you need to calculate your points values.(This depends on what you are trying to draw)
//In a sphere soude code example
               for(index;index<spherePointsSize;index++)
                           x=//do some math to calculate x in a sphere
                           y=//do some math to calculate y in a sphere
                           z=//do some math to calculate z in a sphere
                           //Vector to store our result
                           UT_Vector4 P;
                           //Setting vector values
                           P.assign(nx,ny,nz,1);
                           //Setting the position of the points appended before
                            sphere_points[i]->setPos(P);
//So far you have a set of points that define a sphere to draw them you need to create a primitive and assigned it vertices values
//drawing sphere
                //Creating a pointer to our new to be primitive polygon
                GEO_PrimPoly* prim_poly_ptr;
               //Drawing loop
                for(int fn=0; fn<number_faces; fn++)
                       //Creating a polygon and setting its size to zero as is shown in the api example
                       //This polygon has no vertices yet
                       prim_poly_ptr = dynamic_cast <GEO_PrimPoly*>(gdp->appendPrimitive(GEOPRIMPOLY));
                       prim_poly_ptr->setSize(0);
                       //Now you append  vertices to that primitive polygon and pass them a reference to the point that they correspond from our sphere point list
                       //In this example I draw my sphere as quads since it was easier to procedural mapp the points to an index
                       //Point 1
                       prim_poly_ptr->appendVertex(sphere_points[p1_index]);
                       //Point 2
                       prim_poly_ptr->appendVertex(sphere_points[p2_index]);
                       //Point 3
                       prim_poly_ptr->appendVertex(sphere_points[p3_index]);
                       //Point 4
                       prim_poly_ptr->appendVertex(sphere_points[p4_index]);
                       //Closing the primitive to make it a polygon instead of a poly line
                       prim_poly_ptr->close();
Note that this is just to explain how is that houdini interpretes geometry. To calculate the points on the sphere or the mapping between
the faces and the point indexes I recommend you take a look at these two links.
Sphere Mapping
Polygon Mesh
Edited by cgTux
