FLIP Detailed Collision
djwarder
Hey guys
I'm doing a sim where some FLIP fluid collides with a ground collider & spreads into the grooves between some pavement slabs. However I don't seem to be able to get the SDF to be fine enough for this resolution of collision. Instead I'm thinking of having particles move along the lines & then get the fluid to follow them but not sure how exactly to do that or if there's a better way. Any ideas please?
Cheers
Dan
also make use of -/+ offset of sdf
so you can control interpenetration better
in case like this they can probably sink a bit in fluids i mean
as you wont see under side i imagine
so you dont get them floating above pavement
good luck
once you read sdf back in be sure to switch off volume based collision box
it gave me some headache :)
