diffuseRGB lighting
  • 2 weeks later...
Do you want an image plane that has just the Diffuse colors in it? If that's all you want then just go to the Output tab of the mantra ROP and add an image plane. Look in the VEX variables list for the diffuse channel (there are a number of automatic one, and if you write a custom shader you can add your own). Is that what you're looking for?
hi jim
i wanted to know how to setup the rgb diffuse light pass.i think the rgb light pass is not in the list of vex variables in mantra
Ah, sorry, you want light info, then that's a little different deal, though I'm pretty sure that's possible through the image planes too. There's a Peter Quint lighting tutorial where he discusses how to export the light data - maybe that's worth checking out?
