Fluid collide with fur
jesschaco
Hi All!
I have a scene in which drops of the fluid drip from a table edge. When the drops collide with the cg carpet (made by the fur sop ) , it will start to expand in volume as it travels in a guided direction. As the head of the fluid blob travels through the guided directions, the tail of it gets absorbed slowly into the carpet.
I originally used SPH fluid, but it doesn't seem to detect the fur for collision (it just collides right through the wires). I figured in order to get the level of control that I want from the fluid, I'd have to simulate this with pops. I was wondering what approaches should I make in order to accomplish the kind of absorption I described above? :(
Much Thanks!!!
here is a lesson that involves fluids and fur. maybe something in it will help bro.
-----> 3d World Fur Lesson LINK
:rolleyes:
Hmm...I have tried the tutorial a month ago, but it only deals with attribute transfer to achieve wet hair clumping and color changing effect, not the fluid hair collision I was talking out....:(
I wonder if I could use some kind of erosion of the fluid surface to mimic the water absorption... :huh:
maybe this is a bit obvious, but...are you using a Fluid Force DOP? I know many people forgets it, and it´s the only way to get FLIPs and SDF fluids to interact with deformable objects...not sure about SPH though...
I see! didn't know there was such a thing until now!! Thanks so much, I will give it a try!! :D
i would avoid using the fur in the simulation directly and instead use an SDF to determine whether particles are in the fur "zone" then add a force which pushes the particle towards the surface for a sticky-effect
With SDF...hmmm... What should I use to create sdf for fur? With iso offset?
BTW, this is a reference video of the water spill:
Notice that the fluid sinks in (or gets absorbed) with various speed. I wish to simulate my scene's fluid to the movement of the fluid in the video as closely as possible. Except that my scene's fluid is some kind of magic fluid that it keeps traveling and expanding in guided directions......... :(
Edited by jesschaco
