dragon7 Posted September 18, 2011 Share Posted September 18, 2011 Hi I'm trying to cycle an animation with fetch->cycle->export and it seems to override the wrong channels/parameters. Is there any solution to this? greetings, dragon (noob here, please be patient -.-') Quote Link to comment Share on other sites More sharing options...
crin Posted September 18, 2011 Share Posted September 18, 2011 If you right click on the parameters you would like to loop you can go to "motion effects -> cycle" this will create a chop network for you that will cycle the animation. Quote Link to comment Share on other sites More sharing options...
dragon7 Posted September 19, 2011 Author Share Posted September 19, 2011 This works fine for a single parameter, but if I try to do it on all channels I'm getting an error... Quote Link to comment Share on other sites More sharing options...
dragon7 Posted September 27, 2011 Author Share Posted September 27, 2011 No solution? This is starting to give me headaches... Quote Link to comment Share on other sites More sharing options...
edward Posted September 28, 2011 Share Posted September 28, 2011 Backup your .hip file first. Now try deleting your motionfx chop network and doing it again. Quote Link to comment Share on other sites More sharing options...
dragon7 Posted September 28, 2011 Author Share Posted September 28, 2011 I've tried. again and again... It doesn't work. Quote Link to comment Share on other sites More sharing options...
edward Posted September 29, 2011 Share Posted September 29, 2011 Where are you right-clicking on to create the cycle? I just tried a simple case on a channel group and got no errors. I don't think there's enough info here to help you unless you post your .hip file. Quote Link to comment Share on other sites More sharing options...
dragon7 Posted September 29, 2011 Author Share Posted September 29, 2011 I right-click an the group in the channel editor. I attached the file - I would be really glad if you can help. Raerejhu_cycle.hipnc Quote Link to comment Share on other sites More sharing options...
edward Posted October 1, 2011 Share Posted October 1, 2011 It seems that you have some invalid channels on the Character Placer Translate and Rotate parameters. If I delete those channels first, then the Motion FX > Cycle works. Quote Link to comment Share on other sites More sharing options...
dragon7 Posted October 1, 2011 Author Share Posted October 1, 2011 Thank you! It works now. Quote Link to comment Share on other sites More sharing options...
