cloudfx Posted October 7, 2011 Share Posted October 7, 2011 source from obj has been changed to -source from volume -source from surface -source from point in H11? I dont see source from obj in the shelf and when I source from volume it does not come in as static obj as it did before into autodop network. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted October 7, 2011 Share Posted October 7, 2011 (edited) simple answer : yes, it has been changed in H11 if you select it from the shelf menu, you should get a source apply node, everything you want must be inside that node. Edited October 7, 2011 by ehsan parizi Quote Link to comment Share on other sites More sharing options...
