asnowcappedromance Posted October 12, 2011 Share Posted October 12, 2011 (edited) Hey guys! I'm working on a shot right now where I'm supposed to make an animated object look like jello. I started trying to create the motion with the spring SOP, couldn't get the desired results, found the Softbody POP really nice to control but too unstable (dealing with complex geometry), also it only reads the geometry when the node is first activated so animated geo doesn't work with it - so I ended up playing around with the Squishy Object DOP. Now my questions: Is it possible to control the particles that are created by the Squishy Object? In the sample scene that I added there are 2 groups to be found: gravity_group >> I want those points/particles to be affected by a multiplied gravity force static_group >> Those points should be stationary, or not jello-like (in the spring SOP or Softbody POP there's the option to chose fixed points, is that possible in DOPs somehow?) Or if that doesn't work with the Squishy Object, any advice on how to make the Softbody Pop more stable? Thanks for any tips, have a look at my sample scene! regards, Manu Squishy_Object_Animated_v02.hip Edited October 12, 2011 by asnowcappedromance Quote Link to comment Share on other sites More sharing options...
Solitude Posted October 12, 2011 Share Posted October 12, 2011 Hey guys! I'm working on a shot right now where I'm supposed to make an animated object look like jello. I started trying to create the motion with the spring SOP, couldn't get the desired results, found the Softbody POP really nice to control but too unstable (dealing with complex geometry), also it only reads the geometry when the node is first activated so animated geo doesn't work with it - so I ended up playing around with the Squishy Object DOP. Now my questions: Is it possible to control the particles that are created by the Squishy Object? In the sample scene that I added there are 2 groups to be found: gravity_group >> I want those points/particles to be affected by a multiplied gravity force static_group >> Those points should be stationary, or not jello-like (in the spring SOP or Softbody POP there's the option to chose fixed points, is that possible in DOPs somehow?) Or if that doesn't work with the Squishy Object, any advice on how to make the Softbody Pop more stable? Thanks for any tips, have a look at my sample scene! regards, Manu I would try the Wire Solver / Wire Object for the geo instead. You can create an attribute called 'pintoanimation' which will keep the points in your static group still while allowing the rest of the geo to be 'jelloy'. Quote Link to comment Share on other sites More sharing options...
asnowcappedromance Posted October 12, 2011 Author Share Posted October 12, 2011 (edited) sounds like a good idea, how do I constrain the geometry to the wires though? (That is if I want to create the wire lines myself to have full control over attributes and attach the geometry before I feed that into dops) Edited October 12, 2011 by asnowcappedromance Quote Link to comment Share on other sites More sharing options...
Solitude Posted October 12, 2011 Share Posted October 12, 2011 sounds like a good idea, how do I constrain the geometry to the wires though? (That is if I want to create the wire lines myself to have full control over attributes and attach the geometry before I feed that into dops) Just use the shelf tool. It will take your object's geo and make it a wire object in dops. You use the same geo in both places essentially. The shelf tool will also put down a dop import to transform the points based on the wire sim from dops. Quote Link to comment Share on other sites More sharing options...
asnowcappedromance Posted October 13, 2011 Author Share Posted October 13, 2011 already found that out thanks! That's some fun stuff ... My day was already pretty good but you made it so much better Ian )))) Quote Link to comment Share on other sites More sharing options...
