cdsign Posted October 14, 2011 Share Posted October 14, 2011 (edited) Hi all Houdini users I have tried to merge 2 SOP to combine them together but after the plug in the merge node one of it turn into black after render test. I have tested with differences sop like the Default BOX sop and merged it with my model ,the result is still the same the box SOP turn into black after render. however its rendered with noproblem if the other SOP i have merged with is a NURB surface. Please help me out and clarify my issues. Thanks in advace Cheep black render_issue.hipnc bridge_polygon.otl Edited October 14, 2011 by cdsign Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted October 14, 2011 Share Posted October 14, 2011 It usually renders fine even with those errors. All it means is that the two objects merged don't have the same set of attributes which shouldn't affect the render too much. Hard to say more without a hip file. Are both objects that you merge polygon surfaces? Quote Link to comment Share on other sites More sharing options...
cdsign Posted October 14, 2011 Author Share Posted October 14, 2011 It usually renders fine even with those errors. All it means is that the two objects merged don't have the same set of attributes which shouldn't affect the render too much. Hard to say more without a hip file. Are both objects that you merge polygon surfaces? yes, both are polygon surfaces. i will upload the hip file . Quote Link to comment Share on other sites More sharing options...
cdsign Posted October 14, 2011 Author Share Posted October 14, 2011 (edited) yes, both are polygon surfaces. i will upload the hip file . ** i have used the bridge polygon asset to help with modeling aswell ,am not sure is it the problem.so i have attachmented them together in these files Edited October 14, 2011 by cdsign Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted October 14, 2011 Share Posted October 14, 2011 You forgot to lock or include the tiff file that you use for tracing. Quote Link to comment Share on other sites More sharing options...
cdsign Posted October 14, 2011 Author Share Posted October 14, 2011 You forgot to lock or include the tiff file that you use for tracing. i could not upload the trace file due to the file type is not allow in this forum. however ,its even turned black if I tried to merge it with defualt box SOP. i believed the problem must be somewhere in my machine hand part of my model. :/ Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted October 14, 2011 Share Posted October 14, 2011 I figured it out with the Box. It was fairly simple. Just add a Facet SOP before the Merge and tick Pre-Compute normals and you are good to go. PS. You can lock a File node so that it's content is saved with the hip file. Then you don't need to upload it separately. DS Quote Link to comment Share on other sites More sharing options...
cdsign Posted October 14, 2011 Author Share Posted October 14, 2011 I figured it out with the Box. It was fairly simple. Just add a Facet SOP before the Merge and tick Pre-Compute normals and you are good to go. PS. You can lock a File node so that it's content is saved with the hip file. Then you don't need to upload it separately. DS Thank you so much ) I am really appreciated. Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted October 14, 2011 Share Posted October 14, 2011 NP. Good luck with the modeling. Quote Link to comment Share on other sites More sharing options...
