Rvb Posted October 15, 2011 Share Posted October 15, 2011 Hi Everyone! I have modeled a palm tree just like in (not using speedtree btw, just as reference) and I want to get SSS to work. How can I achieve this? The leaves are simple grids slightly bended.I'm using the Mantra Surface Shader but I got no result using the standard leaf shader to . Does anyone know how I can create an realistic leaf? Best regards, Rogier Quote Link to comment Share on other sites More sharing options...
Klockworks Posted October 16, 2011 Share Posted October 16, 2011 SSS is not designed to work on infinitely thin surfaces(ie flat bent planes). However, the mantra surface shader has the ability to do thin walled translucency. Quote Link to comment Share on other sites More sharing options...
zarti Posted October 16, 2011 Share Posted October 16, 2011 cheap and 'safe' .. if leaves have no depth ( single primitives ) : -use a twosided vop node to at least 'transmit' the shadows onto the down side . - oc , you can tweak that side separately too ( shadow intensity , color , etc .. ) Quote Link to comment Share on other sites More sharing options...
Rvb Posted October 17, 2011 Author Share Posted October 17, 2011 Thanks Klockworks and Zarti for both solutions. I searched odforce for the translucency solution and I think it suits my needs! Thanks you! Regards, Rogier Quote Link to comment Share on other sites More sharing options...
