Bake RBD Sim to Key framed Obj
flux
well i am beginner in houdini ... and comming straight to problem...
i have a simulated rbd scene ...can some body tell me how can i bake simulted dop in to key frames
i mean no sim no rbd calculation ..but key frames on all debris an objects...
would be great if someone can answer in detail ...as i am new to houdini.
thanks in advance...
do you need to actually use the keys or do you just want the geometry animating without the sim?
well i need keys on debris .. infact i want to export it to maya ...but i need keyframes on each debri ..
currently i have exported it but every time it(houdini)exports vertex cache(vertex cache maya compatable) ...and it(Maya)imports all debris as one combined poly object with cache node attached.
i tried to bake animation even by separating that objects in to independant pieces but it folows its history and i tried to bake it in to key frames..it does put key frames on all objects but as i detach the cache node from these pieces ....animation doesn't work ..
i even tried to blendshape on copied object but it still doesn't work ..as transform of object dosent move but all vertices does ..
as far as i figured it out it follows the vertices/shape not transform...
and i need key frames on transform/object...
anyway ..i still want to solve it in houdini...that whole Maya story is just to clear the point that i need key frames on object level/transform level ...
i hope my question is clear now..
