Modeling questions
DBaciu
Hello everybody.
I have a few modeling problems that I solved, but in a big ugly way with a lot of nodes.
So I thought that maybe somebody can help me with these.
The images below will illustrate them.
Ps: of course everything must be done in a procedural way...
Vectorblur, thank you very much for your answer.
For the problem 1, you can't see in my image but the box doesn't have the bottom,
which makes dissolve Sop delete the bottom point also.
But I can leave the bottom of the box where it is and delete it afterwards.
Anyway, selecting the edge procedurally for the dissolve Sop to work is problematic.
For problems 2 and 3, yes, it can be solved with curvesect,
but I was looking for a more direct, reliable method.
For problem 3, the triangle sits right on top of the rectangle, there's no gap between them,
and the points that described them must be in the same place after joining.
You moved the triangle in order to overlap them so the curvesect can work more reliable. See image 1.
The question that I have can be described more generally by the image 2:
Can I insert a point at an arbitrary position (on an edge)?
I would use polysplit.
A point 3/4 way on the edge between point 5-6 would be in the following form
p5-6:.75
one can always adjust the new point position using override bias option too.
Cheers!!
Thank you for your replies.
I used them with mixed results.
The thing is that if you want to use them in a procedural way, well... The hell break loose.
Using the clip sop was a good idea though, with some reserve.
Let's say that the primitive to cut is not in XY plane (or YZ or ZX) but is having a random orientation.
I have to orient the cutting plane of the clip SOP to match the orientation of the primitive.
I can extract the normal direction of the primitive using "prim" or maybe "normal"
expression function in the "Direction" parameter of the clip SOP, but this makes the cutting
plane parallel to the primitive to cut. So, the question is: How can I rotate the defined cutting
plane around an axis 90 degrees?
The question is more general: How can I translate the direction information retrieved by using
"prim" expression functions (which I think is a vector) into degrees?
Can be done into an expression? I'm afraid this is involving dot products,
transform matrices an stuff like that...
oc you can do that ,
but you do not necessarily need to align the clipSOP in order to merge both prims .
it was just used to add the point into the rectangle in a precise position . nothing more . =)
below i uploaded another non-ortogonal-version ..
addPointAndMergez2.hipncFetching info...
p.s. : i modified the primSOP which attaches the triangle to the quad .
.. edit : forgot to say that you can move the timeline to see random orientations of source geometry .
Edited by zarti
Zarti, thank you for answer.
Of course the clip SOP doesn't need to be aligned in order to cut
and create the point that is needed to properly fuse the primitives,
with one observation: what happens if the cutting plane
ends up (in some particular case) parallel with the primitive to cut?
Remember this must be procedural...
Anyway, I still want to find a way to translate from extracted direction to rotation.
Or at least to rotate the vector.
Even without any effort about a gazillion uses for that are crushing into my mind...
