PartyMummy Posted October 19, 2011 Share Posted October 19, 2011 I am creating a scene with an uncurling leaf petal, and I would like to add some subtle dynamics to it. I was hoping to simplify this a bit by using a Spring SOP, but I am having trouble achieving the desired effect. The scene file is attached. The "spine" of the leaf and the leaf itself are two separate objects merged together. The curling (controlled by the "curl" parameter on the obj level) is driven by bones. What I would like to do is add a subtle "bouncing" effect (perhaps that's not the best way to describe it, but it makes sense to me) to make it a bit more realistic. I have looked through Houdini's examples for the Spring SOP as well as some I found in the forums, but can't seem to find any that apply to what I'm wanting to do. Thanks! petal_curl.hip Quote Link to comment Share on other sites More sharing options...
