l-system modeling problem
AlexP
Hello
I'm trying to find a solution to one problem with l=system.
I'm trying to make cuts in the tree.
For example, I have a tree height of 20, I need to make 20 cuts in it, to get 20 individual pieces. I do not know how to write it an L-Systems and is it possible at all. Of course I could just model tree and make cuts, but it not a good way. thank you and sorry for my english.
Hey,
Can you attach your scene file?
Hello
Two ways I can think of:
As you grow the tree, you can put each section of the trunk in to a different group or assign an attribute and increment it per piece you wish to isoate. After the l-system, it is trivial to isolate each section either by attribute or group and then using a Divide SOP, extract the edges to get your cross-section profiles.
See the help on the l-system SOP to get the rule to create groups and attributes:
http://www.sidefx.com/docs/houdini11.1/nodes/sop/lsystem
Edited by old school
