glowy wire shader
jim c
So I tried my hand at creating a shader for a wire/curve, that takes a curve and allows you to animate how the curve "unrolls". It uses a simple particle system to create a trail of particles with an energy attribute. This is then used in the shader along with length and width ramps to create a glowy effect along the curve. So far, so good...except for these annoying points that seem to popup. I've done something stupid here, but I'm not seeing it! Any help would be most appreciated.
The goal is to turn this into a DA that I can then use on a more complex set of curves for my Tron project.
To view it, open the hip, and scrub to back to frame 0, then somewhere between 0 and 36 (that's where I've currently got keys).
wire-test2.hipncFetching info...
Well I feel a little stupid! It would appear that I still had the particle system in the SOP, which I really didn't need. Applying a Delete SOP for prim 0 just before the final Material node, seems to have deleted the particle system but leaving the attribute values intact. Is this the right thing to do? It certainly gets rid of the nasty little point artifacts.
  • 2 weeks later...
  • 4 months later...
  On 11/17/2011 at 7:11 PM, jim c said:
Thanks. I think I got it all sorted out, took a little more experimentation to get the sharp angles in the curve to be handled better, but it looks kind of cool. If anyone's interested I can post the hip file.
hi jim,
hope this is not too late, but i'd be interested in taking a look at your final hip file. I'm just downloading the first one and am taking a look at it.
thanks!
z
  • 1 month later...
