papicrunch Posted November 5, 2011 Share Posted November 5, 2011 hello, I want to objectMerge the "Vector Field Visualization" that you can find into a smoke node when you activate velocity visualization. In The houdini help they said : The Vector Field Visualization DOP visualizes a Vector Field data. The resulting visualization can allow one to determine how a field is behaving over time, or can even be Object Merged into SOPs to produce the final output. so it s seen possible, but I do not understand how. Someone have an idea ? Thank, Thomas Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted November 5, 2011 Share Posted November 5, 2011 you want to make a geometry from your visualization in DOPs? if so, that's possible. Quote Link to comment Share on other sites More sharing options...
papicrunch Posted November 5, 2011 Author Share Posted November 5, 2011 you want to make a geometry from your visualization in DOPs? if so, that's possible. yes exactly, do you know how to do that ? Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted November 5, 2011 Share Posted November 5, 2011 check this out visualization_to_SOP.hipnc Quote Link to comment Share on other sites More sharing options...
papicrunch Posted November 6, 2011 Author Share Posted November 6, 2011 check this out Yeah thank you so simple ... ! have fun Quote Link to comment Share on other sites More sharing options...
loudsubs Posted November 6, 2011 Share Posted November 6, 2011 you can use that velocity field in SOPs as a source for particles, which can give some pretty cool results. Quote Link to comment Share on other sites More sharing options...
papicrunch Posted November 7, 2011 Author Share Posted November 7, 2011 you can use that velocity field in SOPs as a source for particles, which can give some pretty cool results. thank for advice have fun papi Quote Link to comment Share on other sites More sharing options...
