ython - creating local material parameters with python
doc
So I have a geometry object, and on its material tab I can
go to the menu to the right of the "Material" parameter and
"Select and Create local material parameter".
In my case the parameter I'm interested in is called
"occlusion_cash".
how would I go about adding this parameter via with python
commands?
Thanks in advance
L
Drag the parameter to the Python shell. It will give you something like:
hou.parmTuple('/obj/your_object1/occlusion_cash')
then just add .asCode()
hou.parmTuple('/obj/your_object1/occlusion_cash').asCode()
and you will get all the python code nescessary to create the paramter.
