magneto Posted November 11, 2011 Share Posted November 11, 2011 Hi, Sometimes when I am modeling, I often make a selection, add a new OP, then realize, I forgot to select something or missed a component, etc. When I delete the last OP, it disregards my current selection, which forces me to make the selection from scratch. Is it possible to modify the selection easily without selecting everything from scratch? Quote Link to comment Share on other sites More sharing options...
gaurav Posted November 12, 2011 Share Posted November 12, 2011 Hi, Sometimes when I am modeling, I often make a selection, add a new OP, then realize, I forgot to select something or missed a component, etc. When I delete the last OP, it disregards my current selection, which forces me to make the selection from scratch. Is it possible to modify the selection easily without selecting everything from scratch? Yes. if you are interactively selecting components and applying modifiers. than you can press "`" key to break the current tool from the chain above and modify your selection in the viewport itself. once you are done with re selection just hit enter. Cheers!! Quote Link to comment Share on other sites More sharing options...
magneto Posted November 12, 2011 Author Share Posted November 12, 2011 Yes. if you are interactively selecting components and applying modifiers. than you can press "`" key to break the current tool from the chain above and modify your selection in the viewport itself. once you are done with re selection just hit enter. Cheers!! Thanks man, that's great trick. Quote Link to comment Share on other sites More sharing options...
