Is there a way to change the size of gizmos and vertices?
magneto
Basically changing the size of the dots representing the vertices when you edit geometry. Is there a way to change this?
Also when I am using ops like PolySplit, the red cross and the circle that appears over edges are very small. Is there a way to make these bigger?
Lastly where can I change the color of the non-selected vertices when editing geometry?
Thanks in advance :D
