magneto Posted November 15, 2011 Share Posted November 15, 2011 I have loaded a digital asset from the houdini help file and when I middle click on the node, in the middle of the info tooltip/popup, it has a wall of text written by the author I assume, about it's usage. I looked everywhere inside the Edit Operator Type Paramaters dialog, but couldn't find it. Do you know where this text is stored? Thanks. Quote Link to comment Share on other sites More sharing options...
DanBode Posted November 15, 2011 Share Posted November 15, 2011 If you right click on any node in Houdini there is an option called "Edit Comment...". That is where this text comes from. This can be useful for documenting Houdini files before you pass them to someone else. Comments are stored per node and so they're not in the asset definition. Quote Link to comment Share on other sites More sharing options...
magneto Posted November 15, 2011 Author Share Posted November 15, 2011 Thanks Dan, appreciate your reply. Quote Link to comment Share on other sites More sharing options...
