MikeRhone Posted November 17, 2011 Share Posted November 17, 2011 Hey all. I'm trying to evolve a procedure I found here: . Basically, I want to be able to return a list of objects based on their name. I'm pretty new to OOP, but I know MEL well. Is this the standard way to select by name/type in Houdini through Python? My code: def printSearch(term): li = [] for n in hou.node('/').allSubChildren(): if n.name().startswith(term): #print n.path() li.append(n.path) printSearch("Rock") print li Error: Traceback (most recent call last): File "tool_5", line 11, in <module> NameError: name 'li' is not defined Quote Link to comment Share on other sites More sharing options...
tmdag Posted November 17, 2011 Share Posted November 17, 2011 (edited) `li` not a global attribute, it's only inside definition if you for eg. create li before def then it will work li = [] def printSearch(term): etc.. Edited November 17, 2011 by tmdag 1 Quote Link to comment Share on other sites More sharing options...
MikeRhone Posted November 17, 2011 Author Share Posted November 17, 2011 Ack... That is totally it. Thanks a ton Albert! 1 Quote Link to comment Share on other sites More sharing options...
