Load Python Scripts
Anton
Hi, I trying to load my python scripts from Houdini. But as I understand Houdini searchs for scripts only in:
/houdini/python2.6libs;
/houdini/python2.5libs;
/home/user/houdini11.1
The problem is that I should store all python script in my specific directory, for example: /media/WORK/python_scripts
Where I should add path to tell Houdini search for scripts in my folder? Any environment variable?
Thx, I try to set path writing in houdini.env file string: HOUDINI_SCRIPT_PATH = /media/WORK/python_scripts but when i trying to load python file...
execfile(hou.findFile('$HOUDINI_SCRIPT_PATH/Privet.py'))
export = programma()
... i have an error
What I'm doing wrong?
I think HOUDINI_SCRIPT_PATH is the variable for Hscripts not for Python scripts
http://www.sidefx.co..._guide#id387686
The construction:
wouldn't work because python wouldn't convert string "$HOUDINI_SCRIPT_PATH/Privet.py" to something like "/media/WORK/python_scripts/Privet.py"
For this script to work you should probably do something like:
execfile(hou.findFile(os.environ['HOUDINI_SCRIPT_PATH']+'/Privet.py'))
But it seems to be not very convenient. Через одно место, вобщем :)
You can set PYTHONPATH variable where python (and hython) will look for modules
http://docs.python.o...ule-search-path
Or append your favorite path to sys.path directly in your program before importing module:
import sys
sys.path.append("/media/WORK/python_scripts")
import Privet
