Distribution of Random Numbers
Macha
Does anyone know of an easy way to get random numbers (in vopsop preferably) from a probability distribution?
Ideally I'd like to draw a curve in an editor, or use a ramp, and sample from it.
I've kind of come up with a solution where I create a bunch of points, ramp a color (say red) and then randomly (constant distribution) sample from this with the color representing the probability. It works but there should be a prettier way of doing this.
Edited by Macha
I'm not sure that I understand correctly; but to discretely control the values of my random numbers I usually assign standard 0-1 rand, then create an animation curve from frames 0-100, create a new attr that refs both the randAttr and AnimChan -
chf(animChan,randAttr*100)
this gives a lot more control than a ramp, as you can adjust the bezier handles to really get the distribution you are looking for...
-=3db
Hmmmmmm, I think what you do is a similar idea but with a subtle difference. I think you don't change the distribution density but clip it away whereas the method I use makes the distribution denser where the area under the curve would be bigger.
I wish I could post a file!
Edited by Macha
It's not really a clip as much as it is a LUT, but yeah I'm not really sure what you are getting at, cuz on the scatter sop you can scatter bassed on an alternate atribute which determines the probability/density... Alternativiely you can scatter in a volume where desnity=probability..
  • 2 years later...
