modelling and uv doubt
Hello world
I have split the model into several groups so that i can animate the geo part by part.now how do i apply texture.
I have applied uvproject node and a uvquickshade.
found that i had some problems.now i have corrected the normals but still the problems continues.so i have applied the fuse node.this solves the texture problem but now if i check the connectivity.I see all my groups are now been removed.
Please tell me how to proceed.thank you.
oh uvunwrap node unwraps everything.do we need to manually unwrap? i am really new to cg.please bare with me
i have applied a uvquickshade after that to test.all i can see is the messed up textures with lots of grains.please help me out.thank you
You might want to go through following videos first, just to understand the process better.
http://www.sidefx.com/index.php?option=com_content&task=view&id=996&Itemid=132
