script node
3dbeing
Probably it's friday and this is dumb question, but I'm a little confused about the script node...
It seems to want a file, but if I select a .py file it errors... it is on python and node is set to python...
if I put in something like print '123'
it does this fine.
Now if I put in:
hou.pwd().geometry()
i get an infinite recurssion error...
where is this recursion coming from?
Thanks,
-=3db
You can't ask the node to give you its geometry when it hasn't cooked yet. Personally I don't think the Script SOP and Python are very useful, which is why I created this (particularly the SOP):
Ummm, yes! This is exactly what I want form a python sop!!
Cheers Grahm
ps,
took a look at the other stuff, wow what a smorgusmorg(sp?) of Houdini goodness!
But I seem to be missing the inlinecpp python module? Im on windows and latest Houdini build.
ahhh just found this thread ... :blink: I think I'm in over my head again...
I checked and I can import inlinecpp in the py shell, but when I try and plug in a box to the poly-round i get
Error:       Python error: Traceback (most recent call last):
  File "<stdin>", line 36, in <module>
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.67/houdini/python2.6libs\hou.py", line 16720, in __getattr__
    def __getattr__(*args): return _hou.HDAModule___getattr__(*args)
AttributeError: 'module' object has no attribute 'getConnectedPrimitives'
Edited by 3dbeing
