Is it possible to link an integer control to an Ordered Menu?
magneto
In my Python SOP, I have an Ordered Menu and also an Integer control (slider). I want to link them together so that using one sets the value of another.
Basically if you select the 5th element, I want the slider to show 4 (or 5) for instance. I also use string tokens inside the Ordered Menu because I am relying on it, but if I need to make them integer to make this work, it's ok.
