Is there a way to include Python code into Python SOPs as a block of c
magneto
I am looking for a way to insert the contents of a python file into a Python SOP, so I can have the actual SOP code in an external file while the SOP code only loads it. For instance something like this:
include "$OperatorTypeName.py"
This is more of a compile-time thing where it literally copy/pastes the contents of the file.
Is this possible? :)
Thanks Graham, that would work too. Although the less code I have in the SOP, the better :)
Also in the include method, I wouldn't have to look at the internal SOP code or change it ever again, hence me also using the $HDA_NAME.
Edited by magneto
