add attrib vop
a quick question! i added scale parameter in add attrib.found that only x and z directions are scaling.any solutions for scaling in y?
thanks
As Christian already pointed it out. Try using a box instead of a grid, and it should work.
You may also look at the scale vop to have a greater control over things.
Build your transform matrix however you want and multiply with P.
Cheers,
